Stratix 10 GX L-Tile Dev Kit and PCIe
John Sambrook
Common Sense Systems, Inc.
Hi John,
Can you provide me your device OPN number ?
I will generate a .sof file on behave and then sent it back to you.
Wincent_Intel
- JSambrook_CSSI_FPGA3 years ago
Hello Wincent,
Thank you kindly for your help with this.
The Ordering Part Number is 1SG280LU2F50E2VG.
Will you test the design in the same kind of development kit as I have, so
that what you send me is something I know has been proven to work in
other development kits of the same kind?
My development kit is a DK-DEV-1SGX-L-A.
Will the design you compile include support for JTAG debug via Signal Tap,so that the most important signals for assessing enumeration problems arevisible?Thanks again for your help.Best Regards,John SambrookCommon Sense Systems, Inc.- Wincent_Altera3 years ago
Hi John,
I will help to generate the .sof file and .stp file for you.
But I do not have the specific hardware on my place.
Might need you to help test it once done, but I will ensure that it is workable.
Forget to ask which version of Quartus that you are using currently.- JSambrook_CSSI_FPGA3 years ago
Hi Wincent,
I am using Quartus Prime Pro 22.3.
Thank you for your help.
John Sambrook
