JSambrook_CSSI_FPGA
3 years agoStratix 10 GX L-Tile Dev Kit and PCIe
Hello -
I have one of the Stratix 10 GX development kits, the L-tile version.
The card is installed in a Dell Precision 5820 chassis, in slot 4, a x16 Gen3 slot.
I'm looking for a known-goo...
Wincent_Altera
3 years agoHi,
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
- JSambrook_CSSI_FPGA3 years ago
Hi Wincent_Intel,I would like to leave the ticket open for the time being. If you are not the rightperson to handle it, please escalate it.I think it would be Intel's interests, and its customer's interests, for Intel toprovide customers with a known-good and tested design for debuggingPCIe in-host-system enumeration problems.I would like Intel to provide at least a single already-compiled andalready-tested design that can be used as is to check out PCIeenumeration problems in host systems.It could be a simple x1, Gen3 design specifically intended for helping toovercome PCIe enumeration problems. Would it take one of your experiencedFPGA engineers more than an afternoon to put such a design together?It could also be compiled with support for Signal TAP, so that customersthat needed to use that to gain insight into enumeration problems wouldhave additional information to assist in debugging.Best Regards,
John Sambrook
Common Sense Systems, Inc.
- Wincent_Altera3 years ago
Hi John,
Can you provide me your device OPN number ?
I will generate a .sof file on behave and then sent it back to you.Regards,
Wincent_Intel
Hello Wincent,
Thank you kindly for your help with this.
The Ordering Part Number is 1SG280LU2F50E2VG.
Will you test the design in the same kind of development kit as I have, so
that what you send me is something I know has been proven to work in
other development kits of the same kind?
My development kit is a DK-DEV-1SGX-L-A.
Will the design you compile include support for JTAG debug via Signal Tap,so that the most important signals for assessing enumeration problems arevisible?Thanks again for your help.Best Regards,John SambrookCommon Sense Systems, Inc.
