musthafavakeri
6 years agoStratix 10 FPGA programming not happening in Intel® Stratix® 10 DX FPGA Development Kit
Hi All,
I want to program Stratix 10 FPGA in Intel® Stratix® 10 DX FPGA Development Kit. Following are some settings I have given in QSF file as per the board guideline ( https://www.intel.com/cont...
YuanLi_S_Intel
6 years agoBy right if configuration is successful. The design should be programmed into it. Can i check the following with you?
1) What is the bitstream used to program the FPGA?
2) Is your output pointing correctly to the LED on the board?
- musthafavakeri6 years ago
Hi @YuanLi_S_Intel ,
1) am using POF to program the FPGA through AVSTx8 interface
2) set_global_assignment -name USE_CONF_DONE SDM_IO16 is pointing to the fpga_config_done LED on board.
