Stratix 10 Devkit Board Update Portal
Just to double check, the necessary steps that you provided on the post dated 06/09/22 are correct for updating board portal and the board is now operating after carrying out these steps.
If everything is now working alright, I will set your post as solution and set this case to close-pending in the next 2 days. Hope to hear from you soon.
Thank you.
Kelly
Hi Kelly,
Even though I navigated around the errors... nothing works. When I followed those steps the on-board CPLD MAX V flash was completely erased and the board had to be factory restored.
In other words, nothing works. Please read my previous messages on this post; there has been no progress with respect to the board update portal. I navigate through the errors but the end result is broken.
Nick
