n_nuti
4 years agoStratix 10 Devkit Board Update Portal
Dev kit I'm using:
TRANSCEIVER SIGNAL INTEGRITY DEVELOPMENT KIT, STRATIX® 10 GX EDITION
I'm trying to use the "build_hw.sh" script to convert my fpga ".sof" file into a ".bin" file that is usabl...
KellyJialin_Goh
4 years agoHi,
Is there any issue that I can help with? Hope to hear from you soon.
Thank you.
Kelly Jialin
n_nuti
4 years agoHi there. I can't get the board update portal to work properly.
1. For the stratix 10 transceiver signal integrity devkit, quartus can't inherently create the correct kind of "bin" file so I needed to try and create the file using "file -> convert programming files"
2. When I programmed the flash using the board update portal, the board became inoperable and I needed to figure out how to factory reset it.
The rest of the supplemental information can be found in my previous posts.
Thank you.
