RyanT
4 years agoSof2Flash conversion for Ethernet downloading on Arria 10
I encountered Sof2Flash conversion error as shown below. Subsequently, I read that Arria 10 is not supported. If so, how do I convert a SOF file to FLASH file for ethernet downloading on Arri...
aikeu
4 years agoHi RyanT,
Sorry for late reply, may I know what is your connection setup on your board to perform ethernet download?
Are you using a Ethernet blaster for that?
Do you have other connection option like a USB blaster on your board?
Normally we program the board using USB blaster, the board may already have a built in USB blaster without required an external one and only required a mini USB cable connection. Quartus programmer will be used to perform the flash programming.
Aik Eu
