CAlex
Contributor
3 years agoSOC_EDS on windows, can't start the Embendded shell bat
I have problem on opening the Embedded_Command_Shell.bat, when I use power shell to run it, it says:” The system cannot find the path specified.“
I used to use the SOCEDS 18.1 and I uninsta...
- 3 years ago
Okey, the problem is caused by the cygmw tool chain, I already installed that but you have to re-install that in the folder EDS desired.
Please refer to the SOC EDS user guide Intel offered for detail.
EBERLAZARE_I_Intel
3 years agoHi,
For the latest version you do no need it. It will use the "cv_bsp_generator.py" script to take the sources from the handoff folder instead of the bsp-editor.
