Savino
1 year agoSimulating by ModelSIM on quartus|| 9.0 - XOR function bus_signals error in verilog file
Good evening everyone, for several hours I have been running into a problem using quartus|| 9.0 and ModelSim. I have created a very simple project with a bus input and a bus output, and an XOR funct...
- 1 year ago
Hi Savino,
I misunderstood the situation. As mentioned by sstrell, the input must be same width. Using same width will be no problem.
You're using different width, that's why causing the bug.
Sheng
sstrell
1 year agoAn XOR between a bus and a single signal makes no sense. The bus widths must match to perform a bit-by-bit XOR operation.
