Setting True LVDS input and output in MAX10
To avoid this error use the Emulated LVDS standard assignment LVDS_E_3R or LVDS_E_1R.
Thank you.
Hello AminT_Intel,
I know I can use Emulated protocols, my question is about the true ones, shouldn't MAX10 support them ? Why I can't use them?
I want to lower the number of resistors on the board and reach faster signals speeds since True protocols capable of handling faster clocks and data rates.
- AminT_Intel4 years ago
There are requirement to do that and you have to follow the right specification (like example the right I/O standard) to be able to do that. Please refer our to our document (Intel® MAX® 10 FPGA Device Datasheet) on your design.
Thank you
- ABADY10004 years ago
Hello AminT_Intel,
Mr. AminT_Intel, the device supports True LVDS as stated in (Intel® MAX® 10 FPGA Device Datasheet), so why I can't use LVDS in these bank3 and 4 pins ?!
Please if are willing to help me, give me a good answer, not a general statement.
True LVDS input buffer is supported in all I/O banks
True LVDS output buffer is only supported on bottom I/O banks.
Please refer to Intel® MAX® 10 High-Speed LVDS I/O User Guide for detailed explanation.
Thank you.
