12 years agoSending data from Cyclone V FPGA to PC through USB Blaster
Hi All, I have a cyclone V Soc Development kit which has an on board USB blaster II comprising of MAX II and Cypress USB driver CY7C68013A. I would like to transmit data through the USB dri...
12 years ago --- Quote Start --- What happens if you type "help" in that window? If that gets nothing then I think you have a problem with your install. You might try running it with no hardware attached to check your kernel drivers are not causing problems. --- Quote End --- Sorry for the late reply, I am able to get some commands on which i could get info form the help command. I observed an error with the USB connections on the messages section and when i tried the command you had suggested bad error index appears...
