12 years agoSending data from Cyclone V FPGA to PC through USB Blaster
Hi All, I have a cyclone V Soc Development kit which has an on board USB blaster II comprising of MAX II and Cypress USB driver CY7C68013A. I would like to transmit data through the USB dri...
12 years ago --- Quote Start --- Wombat I tried the command sequence in the bottom right script window but there was no response at all... --- Quote End --- What happens if you type "help" in that window? If that gets nothing then I think you have a problem with your install. You might try running it with no hardware attached to check your kernel drivers are not causing problems.
