Regarding maximum achievable bandwidth via the PCIe (v3, x16) interface for the Intel d5005 board
Hi SNEHA
May you guide us on which part of the official specification doc you are referring to? Thanks.
Eng Wei
- SnehaRao5 years ago
Hi !
The datasheet of D5005 card (link here, go to pg 3 of 29) specifies it is a PCI Express Gen 3 x16 compliant card. According to the specification of PCI Express, Gen 3 x16 should give bandwidth of 15.75 GB/s (source here). However we are unable to achieve it.
Sneha
- EngWei_O_Intel5 years ago
Hi SNEHA
The spec you are mentioning here is the ideal case for a PCIE transfer rate. The testing you are doing involve the overhead of data transfer from host to FPGA and back to host. We can't compare both the numbers.
Eng Wei
Hi!
Thank you for your response. I agree that data transfer from host to FPGA and then back to host involves some overhead and thus the specified bandwidth cannot be reached. However, could you kindly let us know what is the practically achievable maximum bandwidth via PCIe (v3, x16) for d5005 board (considering the overhead)? And, how to achieve it? It would be of great help to us.
Thank you
Sneha
