why cyclone v soc HPS running linux can only get 200 BogoMIPS?
Hi Simon,
not fix 200 BogoMIPS issue, i can't get any more help about this issue, and i have checked PLL configuration, it's configured as 800MHz main clock frequency.
for slow boot issue, i think it may be related to your boot media speed, such as NAND FLASH or QSPI FLASH. i have encountered it, root cause is low speed configure of NAND FLASH controller.
best regards
alex
HI AWu6,
thanks for the replay.
The slow boot, and generally the low performance of the processor was caused by a wrong definition of clocks/PLL/oscillators section in the devices tree. I update that device tree section with one found in linux-socfpga, (4.14.x) and everything goes well. Slow boot and generally low performance disappeared.
That devices tree works well with 3.10.x kernel but with 4.14.x no.
With the old device tree seems that the 4.14.x kernel started using a clock frequency lower than 800MHz. No one log or indication was present at startup in boot logs.
Have a good day,
Simone
- minmax5 years ago
Hi @SimoneBo,
I'm facing the same issue on DE10-nano platform and kernel 4.14 or later.
I tried to add some changes to device tree referring .dts file created by sopc2dts and put the updated dtb file to my system, but I was not able to solve this issue. I still see 200.00 BogoMIPS.
Could you kindly tell me what changes you applied to dts file ?Best Regards,
minmax
