Thanks! We just checked the port status by connecting two cages using an Ethernet cable, but
"fpgainfo phy" command still shows they are down:
Board Management Controller, MAX10 NIOS FW version D.2.1.24
Board Management Controller, MAX10 Build version D.2.0.7
//****** PHY ******//
Object Id : 0xEC00000
PCIe s:b:d.f : 0000:08:00.0
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Bitstream Id : 0x23000110010310
Bitstream Version : 0.2.3
Pr Interface Id : f3c99413-5081-4aad-bced-07eb84a6d0bb
//****** PHY GROUP 0 ******//
Direction : Line side
Speed : 25 Gbps
Number of PHYs : 4
//****** PHY GROUP 1 ******//
Direction : Host side
Speed : 40 Gbps
Number of PHYs : 4
//****** Intel C827 Retimer ******//
Port0 25G : Down
Port1 25G : Down
Port2 25G : Down
Port3 25G : Down
Retimer A Version : 101c.1064
Retimer B Version : 0000.0000
I suspect this is a cable issue because all four cards in our testbed show the same symptom. Is there a particular spec for a QSFP cable that is compatible with this card?
By the way, if I understand correctly, the default mode of BD-NVV-N3000-3 is 4x25GbE, where only one of the QSFP cage (i.e., cage A) is active. In this case, when we connect the Ethernet cable from QSFP cage A to cage B, do you still expect that the ports are up if there's no cable or card issue?
Regarding the loopback module, would the one in the following link work for this card?:
https://cablesondemand.com/qsfp-100g-loopback-adapter-module-for-qsfp28-port-testing-3db-attenuation-2-5w-power-consumption-100-gigabit-ethernet-ready-sf-100glb2-5w-3db?utm_source=google&utm_medium=cpc&adpos&scid=scplpSF-100GLB2.5W-3DB&sc_intid=SF-100GLB2.5W-3DB&gclid=Cj0KCQjwi7yCBhDJARIsAMWFScMuBbJujTg3weD0ZE1Z7H88h9qr_b3eVW1sUXOmBlNcgBSjR58T0TQaAs2_EALw_wcB
Daehyeok
