Chandrashekhar_K
2 years agoHow to implement mutual exclusion for critical sections in code?
I have a code, where in the board receives data at a rate of 921600 via uart. This is written into a circular ring buffer in the rx interrupt. The same data is read from the buffer in main in a cont...
CarlosAM_INTEL
2 years agoHello, @Chandrashekhar_K:
Thanks for your clarification.
The device mentioned in your previous communication has its support channel.
We are going to transfer this forum to the proper channel.
The team in charge of this channel will contact you as soon as possible.
Chandrashekhar_K
2 years agoThank you. Awaiting speedy solution.
