Hi @CarlosAM_INTEL ,
I am using Altera Cyclone V SOC Development kit. I have modified the example code provided alongwith namely,
Altera-SoCFPGA-HardwareLib-16550-CV-ARMCC:
The interrupt callback function that writes data into the buffer is modified as below:
volatile unsigned int tail = 0;
volatile unsigned int head = 0;
char buffer[ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE];
void recieveData(ALT_16550_BUFFER_t * buffer1)
#if ALT_16550_BUFFER_ENABLE_SMP
/* Signal we are in the RX section. */
buffer1->isr_rx = true;
#endif
ALT_STATUS_CODE status = ALT_E_SUCCESS;
uint32_t fifo_level_rx;
uint32_t copy_size;
if (status == ALT_E_SUCCESS)
status = alt_16550_fifo_level_get_rx(buffer1->handle, &fifo_level_rx);
/* Copy the RX FIFO into the RX buffer. */
// alt_16550_int_disable_rx(buffer.handle);
// alt_int_global_disable_all();
// portCPU_IRQ_DISABLE();
const unsigned int tail_1 = tail;
const unsigned int head_1 = head;
// portCPU_IRQ_ENABLE();
if(head_1 < tail_1) {
copy_size = stdminul(fifo_level_rx,tail_1 - head_1);
}else{
copy_size = stdminul(fifo_level_rx,ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE - head_1);
alt_16550_fifo_read(buffer1->handle,&(buffer[head_1]), copy_size);
head = (head_1 + copy_size) % ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE;
// alt_int_global_enable_all();
// alt_16550_int_enable_rx(buffer.handle);
/* Disable RX interrupts if the RX buffer is full. */
/* if ((tail == 0) && (head == ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE))
status = alt_16550_int_disable_rx(buffer1->handle);
The function in main that reads bytes from the buffer is given below:
char readBuffer() {
if(tail_1 == head_1) {
return NULL;
const char data = rxBuffer.buffer[tail_1];
tail = (tail_1+1) % ALT_16550_BUFFER_PROVISION_RX_BUFFER_SIZE;
// alt_int_global_enable();
return data;
#define portCPU_IRQ_DISABLE() \
__asm volatile ( "CPSID i"); \
__asm volatile ( "DSB" ); \
__asm volatile ( "ISB" );
#define portCPU_IRQ_ENABLE() \
__asm volatile ( "CPSIE i"); \
I wish to protect access of tail and head. The interrupt function is receiving the whole data. But when we read from the buffer, some bytes are lost ( almost half).
Hello, @Chandrashekhar_K:
Thanks for your clarification.
The device mentioned in your previous communication has its support channel.
We are going to transfer this forum to the proper channel.
The team in charge of this channel will contact you as soon as possible.
- Chandrashekhar_K2 years ago
Thank you. Awaiting speedy solution.
