Error: Could not find or load main class com.intel.bts.BtsApp
I've been able to make some progress by using Oracle Java which I downloaded from
https://www.oracle.com/cn/java/technologies/javase-jre8-downloads.html
The app starts but it gets the following failures, anyone have any ideas?
Starting application on Linux...
Jun 09, 2022 12:33:42 PM com.intel.bts.ClientApp attachServer
INFO: [/usr/local/tools/Quartus_pro_21.2/quartus/sopc_builder/bin/system-console, --server]
Jun 09, 2022 12:33:43 PM com.intel.bts.ClientApp attachServer
INFO: Here is the standard output of the command:
Jun 09, 2022 12:33:47 PM com.intel.bts.ClientApp attachServer
INFO: TCP PORT: 40621
Jun 09, 2022 12:33:55 PM com.intel.bts.JtagInfo createDeviceInfoMapArray
INFO: 2 device detected: /devices/1ST280ES(1|2|3)|1ST280EU1|..@2#3-10 /devices/5M(1270ZF324|2210Z)|EPM2210@1#3-10
Jun 09, 2022 12:33:55 PM com.intel.bts.ClientApp getMatchedBoardInfoArray
INFO: System Max matched: true, Fpga matched: true
Jun 09, 2022 12:33:55 PM com.intel.bts.BtsView startMainStage
INFO: Selected JTAG cable is: USB-BlasterII on localhost (3-10)
INFO: System MAX on index 1, FPGA device on index 0
Jun 09, 2022 12:33:55 PM com.intel.bts.SysConService <init>
SEVERE: java.io.IOException: Get master service paths failed! Device: "/devices/5M(1270ZF324|2210Z)|EPM2210@1#3-10" Type:
Jun 09, 2022 12:33:55 PM com.intel.bts.HeartBeat init
SEVERE: java.io.IOException: Claim master service failed! Type: Path: mem_0
Jun 09, 2022 12:33:55 PM com.intel.bts.InstanceChecker registerInstance
INFO: Application Register. Type: Power or Clock GUI
Jun 09, 2022 12:34:10 PM com.intel.bts.SysConService <init>
Jun 09, 2022 12:34:10 PM com.intel.bts.ClockView init
- JRose4 years ago
I've been able to make it work on CentOS 7.9. You need Oracle Java and you need to set the JTAG speed down to 8000000 and QUARTUE_ROOTDIR should point to 8.1.
Get Java from
Then in Quartus run the JTAG Chain Debugger set the speed to 8000000, run a test and then run this script modified for your system
#!/bin/csh -f
setenv QUARTUS_ROOTDIR /usr/local/tools/Quartus_18.1/quartusecho "The JTAG speed must be set to 8000000"
echo "Run the JTAG Chain Debugger from the Quartus Tools"
echo "In the test set the JTAG speed to 8000000, then run the test"set path = (/usr/local/tools/jdk1.8.0_333/bin /usr/local/tools/jdk1.8.0_333/jre ${path})
cd /usr/local/tools/board_test_system
java -Xmx256m -jar bts.jar -mode clk
