Constants in In-System Memory Content editor
I need to define a constant. Based on a particular value of the constant, I want to perform a specific task.
After the task is performed, I want to change the value of the constant using ISMCE.
Can someone please help me with this?
Pavan
- RichardT_altera5 years ago
Hi @Ppavan
Are you asking on how to edit the Memory Contents in the ISMCE?
You can edit the contents of instances by typing over the existing values directly into the Hex Editor pane.
You may checkout the User Guide below Section 5. In-System Modification of Memory and Constants:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-debug.pdf
YouTube video on how to use In System Memory Content Editor:
https://www.youtube.com/watch?v=_VcVtFvJnuY
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- Ppavan5 years ago
Hi Richard,
Thank you for the reply.
I want to modify a constant (if that is possible) through ISMCE.
I am currently using tcl scripts, not GUI. I have working scripts to read and write data to memory using ISMCE.
I want to do the same to read and modify a constant through ISMCE.
Pavan
You can refer to the scripting available for ISMCE in the User Guide below.
I am more familiar with GUI though. You may need to try out which one works best for you.
I think the write_content_to_memory tcl command is the closest to what you descript.
Richard Tan
