[Agilex}:Issue with Ping Command on I210-T1 Ethernet Server Adapter
- 2 years ago
Hi Intel Communities,
Thank you for your response.
Here are the details you requested:
Intel Ethernet I210 Specifications: I am using an Intel Ethernet I210-T1adapter(1Gbe,Single Port,Copper,RTL Single)
Driver Version for Ethernet and igb: The version of this driver is 6.1.38-243710-g50b63a962d02-dir. The firmware version is 3.25, 0x800006eb.
Kernel Version: The Linux kernel version I am currently running is 6.1.38-243710-g50b63a962d02-dirty.
Thanks & Regards
Satrasala Raju
Hi raju1421,
Thank you for contacting Intel Communities.
Can you please confirm the Intel Ethernet I210 Specifications that you are using?
Kindly provide the driver version you are using for the Ethernet and igb.
Please also share the kernel version that you are using as well.
Kindly let us know if you have any questions.
Hayat
Intel Customer Support
- raju14212 years ago
Thanks & Regards
Satrasala Raju
