Problem running altera_pcie example designs simulation
Problem running Intel Quartus FPGA example test case in:
altera_pcie/altera_pcie_cv_hip_avmm/example_designs/ep_g2x4.qsys
I got this error message when running simv:
Warning-[STASKW_CO] Cannot open file
/nfs/tools/intel/intelFPGA/20.1/quartus//eda/sim_lib/altera_mf.v, 871
The file 'control_onchip_mem.hex' could not be opened. No such file or
directory.
Please ensure that the file exists with proper permissions.
ERROR: cannot read control_onchip_mem.hex.
where can I find control_onchip_mem.hex?
- KhaiChein_Y_Intel
Could you check if the path is correct? It seems like there is a double //. Is this a typo or it is the exact error message you see in the software. If yes, I suspect it is pointing to the wrong path.
KhaiY
- alex2021
The path works even with double //.
I already found the cause. There was a mistake in Generate/Testbench for ep_g2x4. The top module used was "control", not "ep_g2x4_tb". The problem went away after I correct it to use ep_g2x4_tb.
- KhaiChein_Y_Intel
KhaiY
