NM11
3 years agoPower Sequence of Arria V GX (FPGA)
We are using Arria V GX (FPGA) in a prototype we are considering developing. I have 3 technical questions about Power Sequence.
1.
In the Arria V Device Datasheet, at the end of Table 3 of 1.1....
lixy
Contributor
3 years agoHi Naoki,
Sorry for late response.
I communicated further with our team.
About the "monotonic" issue, the power-up process will work fine as long as the power reaches the required voltage level within Ramp Time.
As I mentioned before, we checked the power waveform you provided and only 0.75 V power rail seems to be risky. The "0.2 V" might be a leakage from other power rails, which currently does not seem harmful to the device. However, there might be a risk that this leakage get higher since we do not know how the leakage is caused.
Thanks & Regards,
Xiaoyan
