Power Sequence of Arria V GX (FPGA)
Hi Xiaoyan-san,
Thank you for your answer.
I will check the "VCC_0V75".
Please continue to confirm the influence of "non-monotonic power supply".
Please also consider the following as described on April 5
> So we intend to set the power supply from our system to the FPGA as specified.
Naoki
Hi Xiaoyan-san,
I checked the "VCC_0V75".
This power rail is not connected to other power supplies on schematic.
The cause of the floating from GND was that this power rail was taking a long time to discharge (about 1 minute).
When I turn on the system before the power rail finishes discharging, the voltage rises from about 0.2V.
Is there a problem with a maximum of about 0.2V?
The system appears to be working fine in that case.
So, this power rail is not affected by other power supplies.
I would also appreciate your response to the following questions I have asked you in the past.
Naoki
