JensVkb
3 years agoPossible to simulate error behaviour - On Chip Flash IP?
I would like to simulate the error behaviour of my design, that uses the on chip flash IP.
I'm able to simulate the desired behaviour, reprogramming of CFM0 and CFM1, and I would now like to trigge...
RichardT_altera
3 years agoI checked and the Intel On Chip Flash IP does not have parameters or setting that can be customized to do what you intended. The IP is designed to work as indicated in the UG.
You might need to customize the IP itself.
Richard Tan
