10 years agoPLL on Altera DE3 Development Board doenst work
Hello everyone, im using the developement board altera DE3 (Stratix III , EP3SL150f1152C2N) for my master thesis. Im trying to use a PLL to get a higher clock. Therefor im using the internal 50...
10 years agoI redid my project with the MegaWizard IP Manager. Just like before the project compiles without any error, but i dont get a higher clock out of the PLL.
I used this code:library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
Entity Test9 is
PORT(
CLK : in std_logic;
LEDG : out std_logic_vector (0 TO 7);
DB1 : out std_logic_vector (0 TO 8)
end Entity Test9;
architecture Behavioral of Test9 is
Component PLL is
PORT(
inclk0 : in std_logic;
c0 : out std_logic;
locked : out std_logic
End Component;
SIGNAL CLK_100 : std_logic;
Begin
PLL_inst : PLL PORT MAP(CLK, OPEN, CLK_100 );
DB1(0) <= CLK;
DB1(1) <= CLK_100;
process(CLK_100)
Variable cnt : integer :=0;
begin
if (CLK_100'event and CLK_100='1') then
cnt:=cnt+1;
if (cnt=100000000) then
LEDG <= "11111111";
elsif (cnt=200000000) then
LEDG <= "00000000";
cnt:=0;
end if;
end if;
end process;
End Behavioral;
and LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY PLL IS
PORT
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
END PLL;
ARCHITECTURE SYN OF pll IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (9 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC ;
SIGNAL sub_wire2 : STD_LOGIC ;
SIGNAL sub_wire3 : STD_LOGIC ;
SIGNAL sub_wire4 : STD_LOGIC_VECTOR (1 DOWNTO 0);
SIGNAL sub_wire5_bv : BIT_VECTOR (0 DOWNTO 0);
SIGNAL sub_wire5 : STD_LOGIC_VECTOR (0 DOWNTO 0);
COMPONENT altpll
GENERIC (
bandwidth_type : STRING;
clk0_divide_by : NATURAL;
clk0_duty_cycle : NATURAL;
clk0_multiply_by : NATURAL;
clk0_phase_shift : STRING;
compensate_clock : STRING;
inclk0_input_frequency : NATURAL;
intended_device_family : STRING;
lpm_hint : STRING;
lpm_type : STRING;
operation_mode : STRING;
pll_type : STRING;
port_activeclock : STRING;
port_areset : STRING;
port_clkbad0 : STRING;
port_clkbad1 : STRING;
port_clkloss : STRING;
port_clkswitch : STRING;
port_configupdate : STRING;
port_fbin : STRING;
port_fbout : STRING;
port_inclk0 : STRING;
port_inclk1 : STRING;
port_locked : STRING;
port_pfdena : STRING;
port_phasecounterselect : STRING;
port_phasedone : STRING;
port_phasestep : STRING;
port_phaseupdown : STRING;
port_pllena : STRING;
port_scanaclr : STRING;
port_scanclk : STRING;
port_scanclkena : STRING;
port_scandata : STRING;
port_scandataout : STRING;
port_scandone : STRING;
port_scanread : STRING;
port_scanwrite : STRING;
port_clk0 : STRING;
port_clk1 : STRING;
port_clk2 : STRING;
port_clk3 : STRING;
port_clk4 : STRING;
port_clk5 : STRING;
port_clk6 : STRING;
port_clk7 : STRING;
port_clk8 : STRING;
port_clk9 : STRING;
port_clkena0 : STRING;
port_clkena1 : STRING;
port_clkena2 : STRING;
port_clkena3 : STRING;
port_clkena4 : STRING;
port_clkena5 : STRING;
self_reset_on_loss_lock : STRING;
using_fbmimicbidir_port : STRING;
width_clock : NATURAL
PORT (
clk : OUT STD_LOGIC_VECTOR (9 DOWNTO 0);
inclk : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
END COMPONENT;
BEGIN
sub_wire5_bv(0 DOWNTO 0) <= "0";
sub_wire5 <= To_stdlogicvector(sub_wire5_bv);
sub_wire1 <= sub_wire0(0);
c0 <= sub_wire1;
locked <= sub_wire2;
sub_wire3 <= inclk0;
sub_wire4 <= sub_wire5(0 DOWNTO 0) & sub_wire3;
altpll_component : altpll
GENERIC MAP (
bandwidth_type => "AUTO",
clk0_divide_by => 1,
clk0_duty_cycle => 50,
clk0_multiply_by => 2,
clk0_phase_shift => "0",
compensate_clock => "CLK0",
inclk0_input_frequency => 20000,
intended_device_family => "Stratix III",
lpm_hint => "CBX_MODULE_PREFIX=PLL",
lpm_type => "altpll",
operation_mode => "NORMAL",
pll_type => "AUTO",
port_activeclock => "PORT_UNUSED",
port_areset => "PORT_UNUSED",
port_clkbad0 => "PORT_UNUSED",
port_clkbad1 => "PORT_UNUSED",
port_clkloss => "PORT_UNUSED",
port_clkswitch => "PORT_UNUSED",
port_configupdate => "PORT_UNUSED",
port_fbin => "PORT_UNUSED",
port_fbout => "PORT_UNUSED",
port_inclk0 => "PORT_USED",
port_inclk1 => "PORT_UNUSED",
port_locked => "PORT_USED",
port_pfdena => "PORT_UNUSED",
port_phasecounterselect => "PORT_UNUSED",
port_phasedone => "PORT_UNUSED",
port_phasestep => "PORT_UNUSED",
port_phaseupdown => "PORT_UNUSED",
port_pllena => "PORT_UNUSED",
port_scanaclr => "PORT_UNUSED",
port_scanclk => "PORT_UNUSED",
port_scanclkena => "PORT_UNUSED",
port_scandata => "PORT_UNUSED",
port_scandataout => "PORT_UNUSED",
port_scandone => "PORT_UNUSED",
port_scanread => "PORT_UNUSED",
port_scanwrite => "PORT_UNUSED",
port_clk0 => "PORT_USED",
port_clk1 => "PORT_UNUSED",
port_clk2 => "PORT_UNUSED",
port_clk3 => "PORT_UNUSED",
port_clk4 => "PORT_UNUSED",
port_clk5 => "PORT_UNUSED",
port_clk6 => "PORT_UNUSED",
port_clk7 => "PORT_UNUSED",
port_clk8 => "PORT_UNUSED",
port_clk9 => "PORT_UNUSED",
port_clkena0 => "PORT_UNUSED",
port_clkena1 => "PORT_UNUSED",
port_clkena2 => "PORT_UNUSED",
port_clkena3 => "PORT_UNUSED",
port_clkena4 => "PORT_UNUSED",
port_clkena5 => "PORT_UNUSED",
self_reset_on_loss_lock => "OFF",
using_fbmimicbidir_port => "OFF",
width_clock => 10
PORT MAP (
inclk => sub_wire4,
clk => sub_wire0,
locked => sub_wire2
END SYN;
I get some Warnings like "No clocks defined in the Design", could this be the problem? Thanks in advance
