14 years agoPIO to Memory to PCIe on Arria II GX
Hello, I'm sorry to ask you such simple things, but I'm nearly running mad. My Problem is: I want to check the data of a 32 bit wide general bus. This bus has a clock of 50 MHz. My intention is...
14 years ago --- Quote Start --- I/O --> FIFO --> mSGDMA --> SDRAM (connected to FPGA) --> mSGDMA --> PCIe --> Host memory --- Quote End --- I think the Datas have not to be stored in SDRAM. Since the FiFo can store more than 8000 data packages. So I think this will do the trick: I/O --> FIFO --> mSGDMA --> PCIe --> Host memory I just have to pick up the Datas very fast. And with the FiFo directly attached ti PCIe (via mSGDMA) I have only one adress where the Data is stored and don't need to build another Storage-Structure in the SDRAM. (Correct me if I'm talking absolutely bullsh**.) And I don't have to move the data internally to SDRAM. The only usable FiFo with MM is the On-Chip FiFo which I have now connected as shown beyond. The In-Clock will be later exported and connected to the external clock source of my testdevice. I think with enable bit you mean the "avalonmm_write_slave_write" bit. Can I connect it (externally) to clk_in to automatically trigger writing with 50MHz? Now there is another problem I don't understand: how do I connect the exported Ports to the HSMC-connectors. Normally I would use my soldering iron but I think my boss will kill me if I start soldering on the board :D. OK in Pin Planner, but how does it come that there is no Node or something for FiFo to assign a pin to? What must I do to see the FiFo-Ports in Pin Planner? PS: Don't I need a bridge or something to translate the generic bus into a avalon interface?
