Zarquin
4 years agoPinning for Avalon-MM Reference Design on Cyclone V GTFD9 Dev Kit?
Dear Community,
Intro: I would like to configure the CVGT on my development kit as a PCIe endpoint. To do this, I have worked through this guide and synthesised the Avalon-MM reference design e...
AR_A_Intel
4 years agoAs I understand it, the warning is to remind customer that a bonded XCVR design is used. Due to dynamic reconfiguration is not support for bonded XCVR, the MIF file which was required for reconfiguration is not generated.
If you do not use dynamic reconfiguration, this warning can be safely ignored. Else, if you are planning to perform reconfiguration to the XCVR, you should take noted of the unsupported reconfiguration for bonded XCVR. Can refer to the "Unsupported Reconfiguration Modes" in the Cyclone V Device Handbook, Volume 2: Transceivers for further details.
Zarquin
4 years agoDear AR_A_Intel,
O.K. I see. So probably I can ignore this for now, until I know what dynamic transceiver reconfituration is needed for.
Thank you very much!
