Pinning for Avalon-MM Reference Design on Cyclone V GTFD9 Dev Kit?
Just don't make an assignment for it in the Pin Planner. If you still want to maintain the signal so it doesn't get optimized away, create Virtual Pin assignments in the Assignment Editor for any top-level pins you want to preserve.
Dear Community,
I have learned a lot from your help, but I'm left with unresolved issues:
- How can I prevent the Fitter from auto-pinning signals that I have not manually assigned?
- Where can I find the recommended default configuration for unused input and output pins for CVGTFD9E5F35C7?
And there are still three nodes whose signals are not PIPE simulation only nodes and and yet their pinning is not described in the cv-avmm-manual:
- pcie_cv_hip_avmm_0_npor_npor (input),
- dut_reconfig_busy_reconfig_busy (input),
- pcie_cv_hip_avmm_0_reconfig_clk_locked_fixedclk_locked (output)
I would be very happy if someone had an idea about this.
- Zarquin4 years ago
Got a little further:
1. Avalon MM Reference Design is a Qsys Design, so I could remove Pin-Out-signals
a) by removing it from the Export column or
b) by generating a Top-Level-Unit from within the Pin Planner for the qip-file, then instantiate the qip file in the Top-Level-Unit and comment out unwanted Out-Pins.
c) Also I found a possibility to delete Pins in the Pin Planner using the context menu of the pin.2. For default pin configuration I found:
set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS INPUT TRI-STATED"
set_global_assignment -name RESERVE_ALL_UNUSED_PINS_NO_OUTPUT_GND "AS INPUT TRI-STATED"
in the corresponding Golden Reference Design qsf file.
Hope this is correct and sufficient not to damage the board.3. For pcie_cv_hip_avmm_0_npor_npor I generated a signal by ORing perst and nreset as described here:
npor <= pcie_cv_hip_avmm_0_npor_pin_perst or reset_reset_n;
and assigning it to the port in the Top-Level-Unit-Instantiation. Hope that is correct.
For: dut_reconfig_busy_reconfig_busy (input), pcie_cv_hip_avmm_0_reconfig_clk_locked_fixedclk_locked, still no idea.
I have commented it out in the Top-Level-Unit for now.
