målth
4 years agoPin compatibility between Cyclone V 5CEBA4 and 5CEBA5
On this page :
https://www.intel.com/content/www/us/en/docs/programmable/683375/current/i-o-vertical-migration-for-devices.html
It says that vertical migration path is possible for Cyc...
sstrell
4 years agoVertical migration means that the same package can be used with the same land pattern on the board. As noted on the page you linked to, you can use the pin migration view in the Pin Planner in Quartus to make sure your I/O design will work with the original device and the device you want to migrate to.
