pcie software develop
Hi David,
Can you specify which link you are looking at ? So that I can provide the new link for you.
For BAR size configuration, I suggest you to refer to
It might not be exact what you looking at as that is AVMM design example. Hope this help.
Wincent_Intel
- dsun013 years ago
Contributor
Hi Wincent,
I roughly know how to reconfigure the BAR on the FPGA side. I want to know how to test it on Host PC, for example the Boardtestsystem.exe software. The BAR is predefined by the example FPGA project, if I understand correctly, after I update the BAR content with my application, is there any example/ tutorial to create/update the boardtestsystem.exe software so I can access all memory/register space to test the new FPGA.
now I have a new FPGA on the dev kit board, I need to test it with a customized BTS, I want to know is there any document from Intel to instruct developers to create BTS.
thank you,
David
- dsun013 years ago
Contributor
could you please help find out the following links.
it may be what I am looking for.
Here is updated GUI: http://www.alterawiki.com/uploads/e/e7/GUI_for_AN431.zip
This GUI can be used with Cyclone-V GT example, as well as all previous PCIe examples.
Simple version of software source code: http://www.alterawiki.com/uploads/b/b4/Alt_pcie_qsys_simple_sw.zip
Document of the software : http://www.alterawiki.com/uploads/7/74/Simple_PCIe_soft_readme.doc
- dsun013 years ago
Contributor
Hi Winent,
in another words, I am looking for a tutorial to develop the software in this zip package.
Windows
Revision 1
64-bit Windows driver and application:File:Gui package 090 80000000.zip.
In the package, there is a word document which explains how to install the driver, what additional software needed to be installed, and how to run the application.
- Wincent_Altera3 years ago
Hi David,
For http://www.alterawiki.com/uploads/e/e7/GUI_for_AN431.zip
Please refer to https://cdrdv2-public.intel.com/653681/an431.pdfFor the qsys design,
Please refer to https://www.youtube.com/watch?v=d43Pqc_IZpg&ab_channel=IntelFPGA
There is step by step video there for better understanding.
For the last link, I don't find it in any place, it might be obsolete.
Will submit an internal ticket for the link-broken issue
For other PCIe design, you may get it at
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-guidance/pcie-support.html
Hope this clarified, Regards,
Wincent_Intel
