PCIe design example for Arria10 SX
Any of you familiar with the PCIe design example for Arria10 to help me with the following?
I generated two PCIe design example for Arria10 SX for two different boards (with different Arria10 SX part numbers) using Quartus pro 18.1. I see the following:
- both design pass the simulation test.
- both design fail the same way on HW test. The test shows that read back data is FFFFFFFF, not ABCD1234 as expected.
I use signal tap to look into the rx_st and tx_st buses and I see something strange:
- there is never any activity on the tx_st bus, i.e no tx_st_valid, tx_st_sop, tx_st_eop, tx_st_data.... in other words, there is no data coming back to the host.
- I see some invalid data cycle on rx_st bus, i.e. I see rx_st_valid high but rx_st_sop low and/or rx_st_eop low.
- Once in a while, I see a read cycle on rx_st_data with the data pattern ABCD1234. The read command on rx_st bus (from host to FPGA) should not have any data pattern. Read data should return on the tx_st bus (from FPGA to host). It looks like this is a write command but it is corrupted and becomes a read command.
- Sometime is see an invalid write command with poison bit =1. It looks like a write command is corrupted.
I use Avalon ST, PCIe gen2/3 x4, 64 bit, 250Mhz. The design example seems to target the Arria10 GX development board but I think it should work with Arria SX part on my board since there is no error when i compile for Arria10 SX.
I only have the signals for PCIe bus between the FPGA board and the host. I don't have any of those signals that are available for Arria10 GX development board. This should not be a problem, should it?
Let me know if you want to see some of the waveform on rx_st and tx_st bus. I can capture them and share with you.
Thank you for your help.
- DNguy4
SK Lim,
As I continue to test the design, I notice something unusual. The same design only works in some PCIe slots of the motherboard even though all the slots on the motherboard are PCIe gen3 x8 or x16.
These are good motherboard and all slots work with other NIC cards.
Are you aware of this issue? Any idea to help? Any suggestions?
- SengKok_L_Intel
I'm not aware of this issue, if possible, need to try to understand the difference between these slots, e.g timing of PERSTn, and also when the refclk is stable.
Regards -SK
- DNguy4
Please see the post in this link: https://forums.intel.com/s/question/0D50P00004EYLHySAP/pcie-hard-ip-and-peg-pcie-graphical-slot
- RAM1
Could please share your generated example design of PCIE?
RAM
