himanshuvaria
4 years agoNIOS Processor does not boot using QSPI Flash.
Hello, I am trying to boot Nios II Processor from QSPI Flash on MAX10 dev kit.
For that I have prepared one design that blink one LED via software(.hex). I performed all the steps mentioned in...
KellyJialin_Goh
3 years agoHi,
From the files that you have sent, I do not see a .v file which is also your design file. It should have a verilog file where you write the code for the LED[0] to blink. Try writing a verilog code for your project to allow the LED[0] to blink.
Kelly
himanshuvaria
3 years agoThe .v file which is also the design file for my project is already there. You will find this file at the following location from the previous zip file I attached here.
Location : nios_boot_max10\sys_A\synthesis\submodules\sys_A_led0.v
