NIOS Processor does not boot using QSPI Flash.
I have found more relevant information on how to boot using QSPI Flash with this link here: https://www.intel.com/content/www/us/en/docs/programmable/683689/current/processor-application-copied-from-general.html
For the qsys hardware design, you will need to change the generic_quad_spi_controller_0 to general_serial_flash_interface_0 and change the GSFI parameters according to the QSPI flash size.
Thank you.
Kelly
- KellyJialin_Goh3 years ago
Here is the GSFI IP settings that you need to change after changing your qsys design to a GSFI IP.
Thank you.
Kelly
- himanshuvaria3 years ago
Thank You for your response. I will surely try this one. As I am bit busy with some other work, I can't test it right now.
I will surely go with general_serial_flash_interface_0 instead of generic_quad_spi_controller_0 once I am finished with my work.
Will keep you updated after verifying the changes you mentioned above.
Thank you,
Himanshu
