himanshuvaria
4 years agoNIOS Processor does not boot using QSPI Flash.
Hello, I am trying to boot Nios II Processor from QSPI Flash on MAX10 dev kit.
For that I have prepared one design that blink one LED via software(.hex). I performed all the steps mentioned in...
KellyJialin_Goh
4 years agoHi,
Is the feedback and suggestion provided useful for you? One more point to take note is that pin assignments for the LED[0], which is T20 needs to be assigned on Quartus's pin planner so that it can blink. Hope this could solve your issue.
Thank you.
Kelly
himanshuvaria
4 years agoYes, the PIN Assignment is done for LED[0] as T20 in the PIN Planner. The LED[0] blinks when I run the software project from NIOS TOOL. But the same does not work when I try boot this design using the HEX File and POF File.
