himanshuvaria
4 years agoNIOS Processor does not boot using QSPI Flash.
Hello, I am trying to boot Nios II Processor from QSPI Flash on MAX10 dev kit.
For that I have prepared one design that blink one LED via software(.hex). I performed all the steps mentioned in...
KellyJialin_Goh
4 years agoHi Himanshu,
Any updates regarding the feedback provided? Do you still encounter the same problem when programming the .sof file into the Max10 Dev Kit?
Kelly Jialin, GOH
- himanshuvaria4 years ago
No, I does not encounter any problem when .sof is programmed into the Max10 Dev Kit. Everythings works fine. The only problem I am facing is that I am not able to boot the NIOS Processor where a software code has been written to blink the LED[0] on Power Cycle.
