BigHandsomeBee
5 years agoNios II code only working in debug mode.
I'm testing a very simple led blinking code.
After programming the board, when I click "run" in eclipse, the led blinking code is not working at all.
However, if I click "debug" and enter ste...
BoonBengT_Altera
Moderator
5 years agoHi @BigHandsomeBee,
Apologies for the delayed in reply, managed to review through the design and it look good, with reset vector set, can you please try the following 1) Check the connection of the USB blaster by refreshing the target connection. 2) Also please try to set the stdout to null in the bsp editor. 3) If all things failed, can you please try to use the hello world template to see if the run as will work.
Hope to hear from you soon.
Best Wishes
BB
