User1580871742356367
5 years agoNAND Flash Programming
#1
1. We use Arria 10 SoC 10AS066N2F40 with Micron MT29F1G08ABB NAND Flash.
2. We use or start with A10 GSRD and Arria 10 Flash Programming Alternative from RocketBoards.org to program the NAND (...
BoonBengT_Altera
Moderator
5 years agoThank you for posting in Intel community forum and hope all is well.
I would suggest perhaps to check the datasheet on the micron NAND flash for the write blocks time, it might give some insight of the time required to program is reasonable.
There are also other factors that might influences the time such as binary size, flash part, u-boot (version, optimization level, compiler version), network speed and TFTP server.
Example would recommend to have the TFTP server on the same switch which will improved the speed dramatically.
Please let us know if that clarify some doubts that you have.
Best Wishes
BB
