Multiple .vqm files have module with the same name, which is causing an error.
You may checkout this KDB:
KDB Reference: https://www.intel.com.au/content/www/au/en/support/programmable/articles/000084895.html
Try to compile each .vqm file into a separate design library by Specifying a Destination Library Name in the Settings Dialog Box:
1. On the Assignments menu, click Settings.
2. In the Category list, select Files.
3. Select the file in the File Name list.
4. Click Properties.
5. In the File Properties dialog box, select the type of design file from the Type list.
6. Type the library name in the Library field.
7. Click OK.
Document Reference: https://www.intel.com/content/dam/support/us/en/programmable/support-resources/bulk-container/pdfs/literature/hb/qts/qts-qii51008.pdf
Richard Tan
