spong1303
3 years agoMPN: 5M240ZT100C5N_ washable information - CC Report - CC00000041
Seeking your help to check & provide washable information for below part.
Pls help to check and advise whether below part is washable or not washable by using DI water. Thanks
Part# LA630-2571...
Zawani_M_Intel
3 years agoDear Spong1303,
The Max V device can go through wash with DI water. The important part is to make sure the component/pcb after the wash process to dry out the moisture. This is because the Max V package (T100) is a non hermetic plastic BGA. Moisture can enter the plastic and can cause delamination of the plastic especially near the plastic molding compound/die interface.
Bake process recommendation is at least 125C for at least 4 to 8 hours.
Thank you.
Wani
