SA2205
5 years agomissing source code (increment_leds.c ) on Using Linux on DE-series Boards
the PDF "Using Linux on DE-series Boards" does not come with the source code increment_leds.c on page 26 last paragraph. Which is needed for the rest of the appendixes.
Is there a way to get a hold of this file?
Thanks in advance.
- Hazlina_R_Intel
Contributor
Hi @Lawrence_L_Intel Can you please have someone looked into this?
- Lawrence_L_Intel
The increment_leds.c file is on the SD card under ~/tutorial_files/increment_leds (~ = /home/root). Since you are using code blocks off of the SD card everything is available there. Thanks
