missing fpga leds in yocto build for stratix 10
- 3 years ago
UPDATE -
It was indeed the fit_kernal_stratix10.its file. The default board is set to 0, I switched it to 4 and then deleted the other options to ensure.
I also ran this command that I found not included in the GSRD from the following website as SD boot board id is 4 and not 0 as set default in the GSRD.
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderStratix10
sed -i 's/set_global_assignment -name STRATIX_JTAG_USER_CODE .*/\ set_global_assignment -name STRATIX_JTAG_USER_CODE 4/g' ghrd_1sx280lu2f50e2vg.qsf
These two combined seem to have worked.
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
