Missing drivers
- 6 years ago
COmot, Thank you very much for your response.
All the customized drivers needed for this computer to work properly are provided by HP. The Intel® drivers are generic, meaning they might or might not work with your platform.
If HP did not validate Windows* 10 as a supported OS, then the next thing to do will be to check with them directly if they have the driver needed for your system.
Albert R.
Intel Customer Support Technician
A Contingent Worker at Intel
COmot, You are very welcome, thank you very much for your response.
Yes, correct, the next thing to do in this case will be to get in contact directly with HP for them to confirm if they ave the driver needed available:
Albert R.
