Missing drivers
- 6 years ago
COmot, Thank you very much for your response.
All the customized drivers needed for this computer to work properly are provided by HP. The Intel® drivers are generic, meaning they might or might not work with your platform.
If HP did not validate Windows* 10 as a supported OS, then the next thing to do will be to check with them directly if they have the driver needed for your system.
Albert R.
Intel Customer Support Technician
A Contingent Worker at Intel
COmot, Thank you very much for sharing those details.
Yes, that is correct, the driver actually belongs to Intel® ME/Intel® TXE and the reason why the driver is missing, since this computer is not that new, is because it is not fully compatible with Windows* 10, you can always install that OS but some drivers like the one you are looking for will not be available.
I looked for the driver in HP's web site for the HP dv5-1251nr and I was not able to find that product, I found a similar one HP Pavilion dv5-2231nr and it said that it only supports until Windows* 7:
So, in this case, the next thing to do will be to get in contact directly with HP for them to confirm if Windows* 10 is fully compatible with the laptop and to verify if they have that driver available for you to install it.
Albert R.
- Omoth6 years ago
I found that already but can't install it:
I thought I could find the driver direct from Intel.
