Meet issue when enabling Avalon memory mapped IP on S10 GX dev kit card
- 4 years ago
Thank you so much for reply.
I just solved this issue by choosing the correct target dev kit when compiling the IP design. This issue is caused by the wrong pin mapping.
I found that programming the FPGA has just failed. Maybe that's why the PCIe cannot detect the card.
I have checked the device id. The ordering code of s10 dev kit card is DK-DEV-1SGX-L-A.
So I chose the device in Quartus Software like this.
While in Programmer box, there is no 1SG280LU2F50E2VG, so I chose 1SG280LU2F50.
Is it caused by wrong selection for device ID that I cannot program the sof file to the card successfully? Or any other insights about the reason?
Look forward to reply. Thanks.
This issue is solved after adding necessary QSF setting to the configuration. While the card still could not be detected via PCIe.
