Meet issue when enabling Avalon memory mapped IP on S10 GX dev kit card
- 4 years ago
Thank you so much for reply.
I just solved this issue by choosing the correct target dev kit when compiling the IP design. This issue is caused by the wrong pin mapping.
I found that programming the FPGA has just failed. Maybe that's why the PCIe cannot detect the card.
I have checked the device id. The ordering code of s10 dev kit card is DK-DEV-1SGX-L-A.
So I chose the device in Quartus Software like this.
While in Programmer box, there is no 1SG280LU2F50E2VG, so I chose 1SG280LU2F50.
Is it caused by wrong selection for device ID that I cannot program the sof file to the card successfully? Or any other insights about the reason?
Look forward to reply. Thanks.
- He4Forum4 years ago
This issue is solved after adding necessary QSF setting to the configuration. While the card still could not be detected via PCIe.
