zyadmohammeed
4 years agoMAXV CPLD I/O problem
I have MAX V CPLD there is a problem with the I/O pins when I assign Signal on the I/O some of these I/O fails to out put the signal correctly.
for example, I wrote a dummy Verilog design ...
Farabi_Altera
4 years agoHello,
Can you share your simple design so I can test with our devkit?
Most of the time, the root cause could be the pin assignment where you assigned a specific pin, but the VCCIO of that pin does not matched with the real VCCIO on board.
regards,
Farabi
- zyadmohammeed4 years ago
sure Here is our testing design the pins that are not working Pin (7,24,39,48,52,63)
this example should drive high on all the pins
