MAX10 FPGA high power consumption during programming of on-chip flash
Possible device defect? How many you seeing this behavior?
The inrush current should not take more than a second.
regards,
Farabi
- peejam4 years ago
Hi Farabi,
Thanks for the confirmation that this current is not correct. I do not see it as a typical "inrush" current becatuse it lasts for the entire duration of the flash programming.
I have tested it on 2 devices, with the same effect.
Could you confirm what is the expected current during programming of the internal flash in MAX10?
Currently I suspect some layout issues, where some pins might not be connected as intended. My plan is to cleanup this layout, redo the PCB and test it again.
- Farabi_Altera4 years ago
Hello Peter,
I am getting internal data for this request. I will get back to you once I have the information.
regards,
Farabi
