AAAAAAAAAA
4 years agoMAX 10 Configuration Flash Memory (CFM) how to write to it?
I have a 10M08SCE144I7G device connected via JTAG using the Altera USB-Blaster II and Quartus Prime 21.1 Lite Edition. I want to program the configuration flash memory but I get this error:
``` Er...
NurAiman_M_Intel
4 years agoHi,
What is the frequency used? Can you try to lower the frequency to 6MHz?
Is there any other changes that was done for programming the new FPGA compare to the old one?
Did you follow the pin connection guidelines?
And follow the Max 10 configuration userguide to program CFM.
Aiman
