14 years agoLVDS receiver resistors
I'm currently developing on a DE2-115 together with an HSMC daughter card (TI's ADS58B18EVM through HSMC-ADC-bridge adapter). I need to use LVDS I/O standard for interfacing the cards, so I know I ha...
14 years agoI'm currently developing on a ArriaII EVM together with an HSMC daughter card (TI's ADS62p29EVM through HSMC-ADC-bridge adapter).(that's very similar to your design) I also need to use DDR LVDS for interfacing the cards.
But I'm a freshman with this interface and are confused about DDR LVDS. I want to see the actual waveform using signaltapII. I added a DDRIO_in megafunction to interfacing the ADC chip.Pin IN[5:0] and INCLK are from ADS62P29 and SIGNAL_TAP_CLK is used in the signaltap clk. But it can't compile successfully.I got an fitter error:Folling 6 routing resources needed by more than one signal during the last fitting attempt.The 6 pins are IN[5:0]. Do I miss something like sdc or regenerator the INCLK in the PLL module, I really don't know how to find this informations. Many thx. Regards, Alan
