JTAG-Problem: Unable to scan device chain on CV GT Development Kit
Dear Community,
- JTAG no longer works on my CV GT Dev board since yesterday, without any apparent cause. I have worked with an external USB-Blaster cable until now (Error message Fig.1). The cable is not the cause. I tested it with an other board.
- I tried to use the internal USB-Blaster, but unfortunately that doesn't work either (Error message Fig.2).
- All the switches are to their default settings.
- I opened the JTAG Chain Debugger and did a JTAG Chain integrity test for the external USB Blaster (see Fig.3 below). Seems something with the JTAG signal lines goes wrong.
- So I had a look at the schematic of the JTAG Header for external USB Blaster (Fig.4) and have looked at it on the board (Fig. 5). I have noticed that some resistors and capacitors are not populated (see red line, Fig.5). But I don't think that's the cause of the problem because it looks like they were missing before when the blaster was still working.
- All the JTAG lines from the external JTAG Header and the internal USB-Blaster Port lead to the MAX II on the underside of the board, which configures the JTAG chain and deactivates the internal USB-Blasterwhen the external USB Blaster is connected (Fig.6). So maybe this is the problem. But I don't have an idea how to check this or whether the MAX II can be reprogrammed.
I would appreciate any ideas of what else i could try to get it to work again?
Best regards
Fig.1 Error Extenal Blaster, Fig.2 Error Internal Blaster
Fig. 3: JTAG Chain Integrity Test
Fig.4 JTAG Header for external USB Blaster
Fig.5 JTAG Header on the board
Fig.6 MAX II
- NurAiman_M_Intel
-To confirm, the JTAG are working well previously and suddenly it is not working?
-What is the Quartus version that was used?
Aiman
- Zarquin
Hi Aiman,
yes, exactly, before it worked and then next day it didn't - for no apparent reason.
The Quartus programmer version is 17.0.
The programmer cabel and the programmer software work well with my other CV dev kit.
In the meantime I even tried again with a new programming cable: Same error message.Best regards
- NurAiman_M_Intel
Sorry for the delay.
The dev kit has on board USB Blaster, can you try using the onboard USB Blaster and see if it is working?
Aiman
- Zarquin
Hi Aiman,
I wish you a happy new year.
- Did you read my initial post at the top of the page?
"I tried to use the internal USB-Blaster, but unfortunately that doesn't work either (Error message Fig.2)." - Is there a warranty on your products?
Is there
- NurAiman_M_Intel
Sorry that I overlook that information.
Before we go for RMA, could you advice below for warranty checking,
I have request some information through forum email . Kindly provide the information.
Aiman
