Amir3
4 years agoJIC file format - after "Examine" operation , why is "Signal Tap" written?
Hello everyone,
In my system, from time to time some of the information in the Flash device goes wrong.
When I perform the "Examine" operation through the Programmer, I see that there is a dif...
- 4 years ago
Please notice that the .jic file header isn't read from the flash device rather than generated during programming file conversion respectively when storing the examined file. I don't know where the "Signaltap" text comes from, probably it has to do with the project loaded by Quartus at the time of examine operation. It doesn't tell anything about the .jic content.
Frank
Farabi_Altera
4 years agoHello,
Did you check the power rails to the flash device? or the signal integrity? if it can load/reload for 500 cycles, it should not caused by the flash contents.
regards,
Farabi
